Author Topic: How to Make PI (Point of Intersection) on Pline Arc  (Read 8175 times)
ymg
Re: How to Make PI (Point of Intersection) on Pline Arc
« Reply #15 on: August 01, 2015, 10:09:20 AM »
Roy,
Old school for sure!!
A bulge of +/- 1 would be a 180 degree curves
which theoretically can happen.
I'll check listpolb but it should repeat the first point
at the end of the list.
Thanks for comments!
ymg
ymg
« Reply #16 on: August 02, 2015, 11:52:48 AM »
Roy,
Here I've modified "listpolb" so that it works with closed polyline.
For the case of bulges equals to +/- 1, I did not bother as in the
context of an alignment such a curve would be split in two curves.
  1. (defun c:calcpi (/ bulge ptcp pct delta/2 ang chord radius tangent enpi pilst)
  2.
  3.    (setq  en (car (entsel "Select Alignment: "))
  4.          lst (listpolb en)
  5.        pilst nil
  6.    )
  7.    (while (> (length lst) 1)
  8.       (if (not (zerop (setq bulge (cadar lst))))
  9.          (setq     ptc (caar lst)
  10.                    pct (caadr lst)
  11.                delta/2 (* (atan bulge) 2.0)
  12.                    ang (- (angle ptc pct) delta/2)
  13.                  chord (distance ptc pct)
  14.                 radius (/ chord (* 2 (sin delta/2)))
  15.                tangent (* radius (tan delta/2))
  16.                  pilst (cons (polar ptc ang tangent) pilst)
  17.                   enpi (entmakex (list (cons 0 "POINT") (cons 10 (car pilst))))
  18.          )
  19.       )
  20.       (setq lst (cdr lst))
  21.    )
  22.    (print pilst)
  23.    (princ)
  24. )
  25.
  26. ;; tan   From std-lib                                                         ;
  27. (defun tan (z / cosz)
  28.   (cond ((zerop (rem z pi)) 0.0)
  29.         ((zerop (rem z (/ pi 2))) 1.7e308)
  30.         ((zerop (setq cosz (cos z))) 1.7e308)
  31.         (t (/ (sin z) cosz))))
  32.
  33.
  34. ;;        ;
  35. ;; listpolb     by ymg                                                        ;
  36. ;;        ;
  37. ;; Parameter:  en,  Entity Name  or Object Name                               ;
  38. ;;        ;
  39. ;; Returns:   List of Points and Bulge in WCS                                 ;
  40. ;;        ;
  41. ;; Notes:      On Closed Polyline the Last Vertex is Same as First)           ;
  42. ;;        ;
  43.
  44. (defun listpolb (en / obj i p l)
  45.    (if (= (type en) 'ENAME)
  46.       (setq obj (vlax-ename->vla-object en))
  47.       (setq obj en en (vlax-vla-object->ename en))
  48.    )
  49.    (repeat (setq i (fix (vlax-curve-getEndParam en)))
  50.       (setq l (cons (list (vlax-curve-getPointAtParam en (setq i (1- i)))
  51.                              (vla-getbulge obj i)
  52.                     )
  53.                     l
  54.               )
  55.       )
  56.    )
  57.    (if (= (vla-get-closed obj) :vlax-true)
  58.       (append l (list (car l)))
  59.       l
  60.    )
  61. )
  62.
roy_043
  • BricsCAD 18
« Reply #17 on: August 04, 2015, 06:05:00 AM »
FWIW: Here is a function inspired by this topic.
  1. ; Obj must be an "AcDb2dPolyline" of the acsimplepoly type or an "AcDbPolyline".
  2. ; Return value: Point in WCS.
  3. ; (mapcar '- (_Geom_PolylineArcTangentialInters (vlax-ename->vla-object (car (entsel))) 0) (getpoint "\nPoint: "))
  4. (defun _Geom_PolylineArcTangentialInters (obj idx / ang bulge ptSta ptEnd)
  5.   (if
  6.     (and
  7.       (< idx (vlax-curve-getendparam obj))
  8.       (not (equal 0.0 (setq bulge (vla-getbulge obj idx)) (_Math_FuzzDefault)))
  9.       (not (equal 1.0 (abs bulge) (_Math_FuzzDefault)))
  10.     )
  11.     (progn
  12.       (setq ptSta (vlax-get obj 'coordinate idx))
  13.       (setq ptEnd (vlax-get obj 'coordinate (1+ idx)))
  14.       (trans
  15.         (append
  16.           (_Geom_XYof
  17.             (polar
  18.               ptSta
  19.               (- (angle ptSta ptEnd) (setq ang (* 2.0 (atan bulge))))
  20.               (/ (distance ptSta ptEnd) 2.0 (cos ang))
  21.             )
  22.           )
  23.           (list (vla-get-elevation obj))
  24.         )
  25.         (vlax-get obj 'normal)
  26.         0
  27.       )
  28.     )
  29.   )
  30. )
  31.
  32. (defun _Geom_XYof (pt)
  33.   (list
  34.     (_Geom_Xof pt)
  35.     (_Geom_Yof pt)
  36.   )
  37. )
  38.
  39. (defun _Geom_Xof (pt)
  40.   (if (car pt)
  41.     (float (car pt))
  42.     0.0
  43.   )
  44. )
  45.
  46. (defun _Geom_Yof (pt)
  47.   (if (cadr pt)
  48.     (float (cadr pt))
  49.     0.0
  50.   )
  51. )
  52.
  53. (defun _Math_FuzzDefault ()
  54.   0.00000001
  55. )
tombu
  • ByLayer=>Not0
« Reply #18 on: August 08, 2015, 04:20:51 PM »
Nice!
Thanks!  :)
Although it may not be what the OP wanted  :|
Turned out it was!
I modified it to work with preselected objects as well including arcs & lwpolylines.  I use right-click menus for modifying so I needed the preselected option.
  1. ; by ronjonp
  2. ; modified it to work with preselected objects as well including arcs & lwpolylines - by Tom Beauford
  3. ; (load "AddArcTangents.lsp") AddArcTangents
  4. ; ^P(or C:AddArcTangents (load "AddArcTangents.lsp"));AddArcTangents
  5. ; http://www.theswamp.org/index.php?topic=49865.msg550417#msg550417
  6. (defun c:AddArcTangents (/ _angle _line e ep p sp tmp)
  7.   (defun _angle (ename pt / ang clpt e param)
  8.     (if (and (not (vl-catch-all-error-p (vl-catch-all-apply 'vlax-curve-getendparam (list ename))))
  9.              (setq clpt (vlax-curve-getclosestpointto ename pt))
  10.              (setq param (vlax-curve-getparamatpoint ename clpt))
  11.              (setq ang (angle '(0 0) (vlax-curve-getfirstderiv ename param)))
  12.         )
  13.       ang
  14.     )
  15.   )
  16.   (defun _line (p1 p2 layer)
  17.     (entmakex (list '(0 . "LINE")
  18.                     '(100 . "AcDbEntity")
  19.                     (cons 8 layer)
  20.                     (cons 10 p1)
  21.                     (cons 11 p2)
  22.               )
  23.     )
  24.   )
  25.
  26.   (princ "\nSelect Arc or Polyline ")
  27.   (setq tmp (ssget "+.:E:S" '((0 . "arc,lwpolyline"))))
  28.   (if tmp
  29.     (progn
  30.       (setq e (ssname tmp 0)
  31.             EnTyp (cdr (assoc 0 (entget e)))
  32.       )
  33.       (if (= EnTyp "LWPOLYLINE")
  34.         (setq tmp (vlax-invoke (vlax-ename->vla-object e) 'explode))
  35.         (setq tmp (list (vlax-ename->vla-object e)))
  36.       )
  37. ;  (if (and (setq e (car (entsel))) (setq tmp (vlax-invoke (vlax-ename->vla-object e) 'explode)))
  38.       (foreach o tmp
  39.         (if (= "AcDbArc" (vla-get-objectname o))
  40.           (progn (setq sp (vlax-curve-getstartpoint o))
  41.                  (setq ep (vlax-curve-getendpoint o))
  42.                  (setq p (inters sp (polar sp (_angle o sp) 1) ep (polar ep (_angle o ep) 1) nil))
  43.                  (_line sp p "Intersection")
  44.                  (_line ep p "Intersection")
  45.                  (if (= EnTyp "LWPOLYLINE")(vla-delete o))
  46.           )
  47.           (if (= EnTyp "LWPOLYLINE")(vla-delete o))
  48.         )
  49.       )
  50.     )
  51.   )
  52.
  53.   (princ)
  54. )
Thanks again!
Tom Beauford P.S.M.
« Reply #19 on: August 08, 2015, 09:21:34 PM »
Nice!
Thanks!  :)
Turned out it was!
  1. ; by ronjonp
  12.    )
  13.       ang
  14.     )
  15.   )
  19.           (cons 8 layer)
  20.           (cons 10 p1)
  21.           (cons 11 p2)
  22.          )
  23.     )
  24.   )
  25.
  28.   (if tmp
  29.     (progn
  32.       )
  36.       )
  38.       (foreach o tmp
  46.      )
  48.         )
  49.       )
  50.     )
  51.   )
  52.
  53.   (princ)
  54. )
Thanks again!
Glad you could make use of it  :)
rashidaziz
  • Mosquito
« Reply #20 on: August 10, 2015, 04:00:18 PM »
Thanks so much all of you,
Awesome work.
Thanks again
