Author Topic: Clip Boundaries for a Raster  (Read 38767 times)
ML
Re: Clip Boundaries for a Raster
« Reply #150 on: November 20, 2007, 07:11:21 PM »
OK
I stand corrected by myself  :-(
The selection set is not why the undo feature is working; it works regardless. DALP!
Of course there may be other reasons to keep it in there; it is completely up to your guys
Kirk out
David Hall
  • Automatic Duh Generator
« Reply #151 on: November 21, 2007, 09:01:53 AM »
Wow, you guys stayed late last night.
ML
« Reply #152 on: November 21, 2007, 09:12:43 AM »
Yes sir
No rest for the weary
ML
« Reply #153 on: November 21, 2007, 10:58:22 AM »
Hey guys,
I know this is a little bit obsessive but I am just curious;
If I select the lower left (llpnt) and the upper right (urpnt) points of the raster,
I have the results printing to the Immediate Window -->
Take note of the results, which are the correct points
'Return picked points
  Debug.Print "The lower left picked points = " & llpnt(0) & ", " & llpnt(1)
  Debug.Print "The upper right picked points = " & urpnt(0) & ", " & urpnt(1)
'From Immediate Window
The lower left picked points = -8, 0
The upper right picked points = -0.3500000000012, 11.6033333333333
However, if I use the code that Bob gave me:
Sub Getpoints()
Dim Pnt As Variant
Dim i As Integer
On Error GoTo NoPoint
Do
  Pnt = ThisDrawing.Utility.GetPoint(, vbCrLf & "Pnt" & i)
  Debug.Print "Pnt" & i & ": "; Pnt(0) & "," & Pnt(1)
  i = i + 1
Loop
NoPoint:
  If Err.Number Then
   Err.Clear
   Exit Sub
  End If
To get my points;
The lower left points (llpnt) are being returned as
-8,-1.34354333214404E-15
Does anybody know why this is happening?
In Bob's code, do we need to have a round function?
In both modules; the same exact method is being used but the results are different?
ML
« Reply #154 on: November 21, 2007, 11:25:34 AM »
In this example:
Sub Getpoints_xymid()
Dim llpnt As Variant 'lower left point
Dim urpnt As Variant 'upper right point
Dim xpnts As Variant
Dim ypnts As Variant
Dim mdpnt(0 To 2) As Double
With ThisDrawing.Utility
 llpnt = .GetPoint(, vbCrLf & "Select Lower Left Point: ")
 urpnt = .GetCorner(llpnt, vbCrLf & "Select Upper Right Point: ")
End With
mdpnt(0) = (llpnt(0) + urpnt(0)) / 2 'Midpoint (X) = (The far left picked point + the far right picked point) / 2
mdpnt(1) = (llpnt(1) + urpnt(1)) / 2 'Midpoint (Y) = (The far bottom picked point + the far top picked point) / 2
mdpnt(2) = 0
xpnts = llpnt(0) + urpnt(0)
ypnts = llpnt(1) + urpnt(1)
Debug.Print "Lower left points: "; llpnt(0) & "," & llpnt(1)
Debug.Print "Upper right points: "; urpnt(0) & "," & urpnt(1)
Debug.Print "Midpoints: "; mdpnt(0) & "," & mdpnt(1) & vbCrLf
Debug.Print "Xpoints (0) + (1) = "; xpnts
Debug.Print "Ypoints (0) + (1) = "; ypnts
Check out the results:
Lower left points: -8,-1.34354333214404E-15
Upper right points: -0.3500000000012,11.6033333333333
Midpoints: -4.1750000000006,5.80166666666667
Xpoints (0) + (1) = -8.3500000000012
Ypoints (0) + (1) =  11.6033333333333
The Y Points are being calculated correctly as Xpoint (1) should = 0
Still, look here, look at Lower left points:
It is giving me -1.34354333214404E-15 instead of 0
WTF!
The question is why?
ML
« Reply #155 on: November 21, 2007, 11:32:10 AM »
Sorry guys
The code should read like this
Debug.Print "Upper right points: "; urpnt(0) & "," & urpnt(1) & vbCrLf
Debug.Print "Xpoints (0) + (0) = "; xpnts
Debug.Print "Ypoints (1) + (1) = "; ypnts & vbCrLf
The correction is:
Still the prior post does has the correct numbers, it was just the way I was displaying the string (in the immediate window) that was wrong
ML
« Reply #156 on: November 21, 2007, 02:08:32 PM »
Hey guys
Just when you thought it was OVER; I have yet one more idea
OK,
If the raster already exists in the drawing, then we can still utilize this code.
I have most of it written
I just need help with the line in red.
Sub InstRast3()
Dim RastImg As AcadRasterImage
Dim Obj As AcadObject
Dim Objname As String
For Each Obj In ThisDrawing.PaperSpace
 If Obj.ObjectName = "AcDbRasterImage" Then
  [color=red]'Objname = 'Need this code[/color]
  Set RastImg = ThisDrawing.PaperSpace.Item(Objname)
 End If
Next Obj
 Dim ImgLmts(2) As Double
 ImgLmts(0) = RastImg.Origin(0) + RastImg.ImageWidth
 ImgLmts(1) = RastImg.Origin(1) + RastImg.ImageHeight
 ImgLmts(2) = 0
 Dim ClipPoints(0 To 9) As Double
'Prompt for pick points on raster and check if the user picks within the raster boundaries
 Dim PntLmts As Boolean
 PntLmts = False
 Do While PntLmts = False
  llpnt = ThisDrawing.Utility.GetPoint(, vbCrLf & "Select Lower Left Point: ")
  urpnt = ThisDrawing.Utility.GetCorner(llpnt, vbCrLf & "Select Upper Right Point: ")
   If llpnt(0) >= RastImg.Origin(0) And llpnt(0) <= ImgLmts(0) Then
    If llpnt(1) >= RastImg.Origin(1) And llpnt(1) <= ImgLmts(1) Then
     If urpnt(0) >= RastImg.Origin(0) And urpnt(0) <= ImgLmts(0) Then
      If urpnt(1) >= RastImg.Origin(1) And urpnt(1) <= ImgLmts(1) Then
       PntLmts = True
      Else
       MsgBox "The pick points must be on the raster image " & vbCrLf & _
       "Please try again"
       PntLmts = False
      End If
     Else
      "Please try again"
      PntLmts = False
     End If
    Else
     "Please try again"
     PntLmts = False
    End If
   Else
    "Please try again"
    PntLmts = False
   End If
  Loop
  mdpnt(2) = 0
 'Create Selection Set for Raster
  Dim Sset As AcadSelectionSet
  Set Sset = ThisDrawing.SelectionSets.Add("Image")
  Sset.Select acSelectionSetLast
  'Debug.Print "Selection Set " & "("; Sset.Name; ")" & " was created"
  With Sset
   'Do whatever
  End With
 'Clip boundary = picked points (llpnt and urpnt)
  ClipPoints(0) = llpnt(0): ClipPoints(1) = llpnt(1)
  ClipPoints(2) = llpnt(0): ClipPoints(3) = urpnt(1)
  ClipPoints(4) = urpnt(0): ClipPoints(5) = urpnt(1)
  ClipPoints(6) = urpnt(0): ClipPoints(7) = llpnt(1)
  ClipPoints(8) = llpnt(0): ClipPoints(9) = llpnt(1)
 'Clip the image
  RastImg.ClipBoundary ClipPoints
 'Enable the display of the clip
  RastImg.ClippingEnabled = True
 'Delete Selection Set
  ThisDrawing.SelectionSets.Item("Image").Delete
Errorhandler:
 If Err.Description = "File access error" Then
  If MsgBox("Can not find image file") Then
   Exit Sub
  End If
 End If
Bob Wahr
« Reply #157 on: November 21, 2007, 02:53:22 PM »
    Objname = rastimg.name
 End If
Next Obj
Bob Wahr
« Reply #158 on: November 21, 2007, 02:56:36 PM »
Does AcadObject work for this or should it be ACADEntity? Also, why not use a filtered selection set.  Probably won't matter but if there are a bunch of thingies in your dwg it will be quicker.
ML
« Reply #159 on: November 21, 2007, 03:03:43 PM »
Hi Bob
Thank you;
Yes, Acadobject or Object will work
From what I have been taught and have learned:
If we declared
Obj as AcadEntity
Then, it will literally interate through EVERY single AutoCAD entity
Lines, blocks, text, polylines, circles and on and on as opposed to just saying
Find the "object" (typeof) (typename =) I need and do something with it
I could do a filtered selection set but these two methods would work in a similar fashion i would think as with this method we are interating for a specific object type not through a drawing of entity types
David Hall
« Reply #160 on: November 21, 2007, 03:04:50 PM »
808, I dont know, I thought it required the object
David Hall
« Reply #161 on: November 21, 2007, 03:06:58 PM »
Actually, without the filter, you will process every object in paperspace.  Given that paperspace doesn't usually have tons of items, it should go quickly.  If however you were processing modelspace, a filtered selection set would be the way to go
ML
« Reply #162 on: November 21, 2007, 03:18:19 PM »
Bob
This won't work
 End If
Next Obj
How are we going to know what objname to set too?
I am able to confirm that there is a raster in paperspace but I need to grab its name
David Hall
« Reply #163 on: November 21, 2007, 03:20:56 PM »
I think you want
Set RastImg = Obj
ObjName=RastImg.Name
Bob Wahr
« Reply #164 on: November 21, 2007, 03:21:26 PM »
doh!  yep, that's what I meant.
