Author Topic: XRef binding  (Read 7323 times)
jonesy
  • SuperMod
XRef binding
« on: May 01, 2008, 04:42:29 AM »
Hi all
I have a quick question.
I have about 200 drawings to get out by the 5th may, and each drawing has 4 or 5 xrefs attached/overlayed.
Our network is/can be incredibly slow, so its taking forever to open-bind-save. Does anyone know of a way that can automate the process reliably.
Many thanks in advance
T :)
CADaver
Re: XRef binding
« Reply #1 on: May 01, 2008, 08:21:10 AM »
Hi all
T :)
grrrr...... never mind
DWGTrueView will batch the process under the "Convert" function.
rkmcswain
Re: XRef binding
« Reply #2 on: May 01, 2008, 08:21:43 AM »
eTransmit includes the ability to bind xrefs. I'm not quite sure of the exact procedure, but you may have to "eTransmit" the drawings to a temporary location and then move them back.
jonesy
  • SuperMod
Re: XRef binding
« Reply #3 on: May 01, 2008, 08:31:49 AM »
Hi all
T :)
I'm sorry to make you Grrr... Randy, specially first thing in the morning... But what the client wants the client gets :)
However, for future reference, could you let me in on how you send your drawings to the client, so maybe we'd be in a position to change their mind for a future issue.
Thanks for the TrueView, I'll look into that too :)
T :)
daron
Re: XRef binding
« Reply #4 on: May 01, 2008, 09:37:11 AM »
The best way to send files to clients is to use eTransmit. It captures all your needed files into a zip file, including unique fonts files and anything else you might want to send. It also puts xrefs with folder structure in said file. Zip it, email it and be done. You can also add a note to them for how to use all the files. I believe the grrr would be because he's biting his tongue on binding xrefs. What you should do about that is time how long it takes to bind and save and send all these files, take the hourly cost you spent on them, multiply by 2, and send them the bill explaining that they just costed you twice the amount of work by binding these files and taking you away from other pressing work that could've been accomplished had they allowed you to just eTransmit the files with xrefs intact.
alanjt
  • Standby for witty remark...
Re: XRef binding
« Reply #5 on: May 01, 2008, 09:47:51 AM »
i agree with daron 100%
for your (crazy) client, you could just batch:
(setvar "bindtype" 1)
(command "-xref" "b" "*" )
(setvar "bindtype" 0)
(command "qsave")
(command "quit")
Dropbox
jonesy
  • SuperMod
Re: XRef binding
« Reply #6 on: May 01, 2008, 09:48:54 AM »
At my last place we used eTransmit almost exclusively, but this client has asked for it to be sent that way. There are no special fonts, shapes etc, so its just the drawing file to consider, so that stops much of the problems.
But everything comes down to what the client wants/willing to pay for, not necessarily how we want to do it :(
Maybe if we get repeat business, we'll try to talk them into using eTransmit.
Re: XRef binding
« Reply #7 on: May 01, 2008, 10:09:34 AM »
Perhaps ask them why they prefer to be all bound up like that?  Perhaps this a matter of just not knowing or wanting to know there might be other ways to handle the data. Just make it sound like you are the one with the pointy hat on, and not them.
Re: XRef binding
« Reply #8 on: May 01, 2008, 10:38:03 AM »
Be aware that if you have any nested xrefs in these files, they will not bind.
daron
Re: XRef binding
« Reply #9 on: May 01, 2008, 10:45:17 AM »
By nested xref, you mean "parent/child/grandchild"? IOW, the main drawing contains an xref that also contains its own xref? Be sure to bind that grandchild first. Like I said, track it, chart it and charge them double for your effort. They'll change their tune real quick.
Re: XRef binding
« Reply #10 on: May 01, 2008, 10:47:36 AM »
By nested xref, you mean "parent/child/grandchild"? IOW, the main drawing contains an xref that also contains its own xref?...
Yes :-)
Guest
Re: XRef binding
« Reply #11 on: May 01, 2008, 11:20:24 AM »
We have a policy to NOT bind any xrefs when we send them out (unless specifically asked begged to do so).
Our reason is simple.  Let's say you have a 5MB xref that is referenced into 10 drawings.  Those 10 drawings, once the xref is bound, grow rather large in size.  So instead of having 10 files of 100KB and one 5MB file, you now essentially have 10 5MB files.  If you're sending the files via an FTP site or email, the person on the other end will soon become slightly "enraged" with 1) the file size and 2) the time it takes to download.
We may save the files as 2004 or earlier and automatically explode AEC objects for the client, but other than that, we leave the files "as-is" and give them a list of the drawings that they need to be concerned with.  And as long as the xrefs are in the same folder as the host drawing, the host drawing will find the xrefs and display them properly.
CADaver
Re: XRef binding
« Reply #12 on: May 01, 2008, 01:22:38 PM »
T :)
I was "grrr...ing" at the client.  We've had a couple of those, we charge an additional $25 per file (project file count, whether they have XREFs or not) to bind XREFs at job completion, and we so state in the contract documents at the start of the job.  Considering that it is common for us to have thirty to fifty thousand or more files on a project, the client usually chokes on the seven figure bill for making intelligent files stupid.
We use eTransmit in a batch process to send all files to a specific directory.  Once there we run a second batch on ALL the files there to do a general cleanup, massive purge, remove all "unloaded" xrefs, and create a pdf of all layout tabs based on a pre-determined pagesetup.  If we know the client's pagesetup structure, we'll add it at this time as well.
Sometimes, as a final sanity check prior to zipping for transmittal, I run DWGTrueConvert on the entire directory to "Check and fix errors" and convert the files to the customer's version of AutoCAD.
For those that don't have a batch process like ours, DWGTrueConvert (contained in DWGTrueView) will do much of the above without eating a seat of the application.  It won't purge or remove unloaded xrefs, but it will "Check and fix errors", set the plotter to "none", replace pagesetups, it'll even bind all the xrefs.
Guest
Re: XRef binding
« Reply #13 on: May 01, 2008, 01:28:31 PM »
T :)
Whoa, whoa, whoa!!  Back the truck up!!!  30-50 THOUSAND files??!?  Is each line an xref?!??   :-o
What in the holy hell.....?!?
CADaver
Re: XRef binding
« Reply #14 on: May 01, 2008, 03:13:21 PM »
That's a file count for a project, not a count of xref's in a file.  A good two-thirds or more of our files contain at least one reference to something, some may have two or three hundred or more.  Does that seem like a lot? This facility will have over ten thousand piping line numbers with two to four iso drawings each.  By the end we may be approaching a hundred thousand drawings in all disciplines, I think the current estimate is above eighty-eight thousand. This model has just under four hundred xrefs and we haven't yet reached the thrity percent model review.
