Author Topic: Dumpbin Exports for acad.exe 2006  (Read 3874 times)
Glenn R
« on: July 07, 2008, 08:46:37 AM »
Could someone post up a .txt file containing these please? I only have Express where I am at the moment, which means no dumpbin.exe  :-(
At Visual Studio command prompt type:
dumpbin /exports "PathToAcad2006Exe" >> C:\Temp\Acad2006Exports.txt
Cheers,
Glenn R
Re: Dumpbin Exports for acad.exe 2006
« Reply #1 on: July 07, 2008, 03:45:13 PM »
Don't worry - done it and saved for future express endeavours.
sinc
« Reply #2 on: July 07, 2008, 07:19:03 PM »
How did you do it?
I use dumpbin from time to time, and all I have is the Express edition.  I had to do some environment configuration first; maybe that's all you need?
As fate would have it, I just posted something about it yesterday:
http://www.quux.biz/Programming/PInvoke.aspx
Spike Wilbury
« Reply #3 on: July 07, 2008, 07:30:28 PM »
You guys might know about this one, too:
http://www.dependencywalker.com/
« Reply #4 on: July 07, 2008, 10:27:03 PM »
OK, I won't worry.  :lol:
I ran out of time this morning, and I was feeling guilty about it ... but the train had higher priority.
MickD
« Reply #5 on: July 07, 2008, 10:30:28 PM »
heh, it was all over before I got here! :laugh:
- John Carmack
- J.R.R. Tolkien
Glenn R
« Reply #6 on: July 08, 2008, 08:45:46 AM »
How did you do it?
Hmmm. I have no files in that VC folder on my 2008 C# Express install...is it possible you have other version of the Express IDE installed as well, giving you dumpbin?
I solved by going home and using Visual Studio 2005 Professional to export the modules.
sinc
« Reply #7 on: July 08, 2008, 08:49:30 AM »
Maybe.  I also have the C++ Express Edition installed...  Maybe it came in with that?
Glenn R
« Reply #8 on: July 08, 2008, 09:04:39 AM »
I suspect so - nice to know though.
It's Alive!
  • Retired
  • AKA Daniel
« Reply #9 on: July 09, 2008, 11:33:08 AM »
Better late than never  :whistle:
Glenn R
« Reply #10 on: July 10, 2008, 04:16:46 AM »
Thanks Dan.
It's Alive!
  • Retired
  • AKA Daniel
« Reply #11 on: July 10, 2008, 07:26:31 AM »
Sorry to hijack the thread but in reading through the exports , I noticed these two methods
acedAppendSearchPath and acedRemoveSearchPath. Has anyone partied with these? I tried to P/invoke them but nothing happened.  :mrgreen:
namespace ExecMethod
  public class Commands
    [DllImport("acad.exe", CallingConvention = CallingConvention.Cdecl, CharSet = CharSet.Unicode,
      EntryPoint = "?acedAppendSearchPath@@YAXAAV?$CStringT@_WV?$StrTraitMFC_DLL@_WV?$ChTraitsCRT@_W@ATL@@@@@ATL@@@Z")]
    internal static extern ErrorStatus AppendSearchPath(string path);
      EntryPoint = "?acedRemoveSearchPath@@YAXAAV?$CStringT@_WV?$StrTraitMFC_DLL@_WV?$ChTraitsCRT@_W@ATL@@@@@ATL@@@Z")]
    internal static extern ErrorStatus RemoveSearchPath(string path);
    [CommandMethod("doit")]
    static public void doit()
      Editor ed = AcAp.Application.DocumentManager.MdiActiveDocument.Editor;
      try
        AppendSearchPath("C:\\Temp");
      catch (System.Exception ex)
        ed.WriteMessage(ex.Message);
        ed.WriteMessage(ex.StackTrace);
Glenn R
« Reply #12 on: July 10, 2008, 07:54:25 AM »
Hmmm...no I haven't and not seeing anything in the docs for them either - but that doesn't surprise me one little bit :)
Spike Wilbury
« Reply #13 on: July 10, 2008, 11:36:57 AM »
First time, I know about them... they are available in a2007 too, but not for example in a2002...
here are the undecorated functions, btw:
void acedAppendSearchPath(
class ATL::CStringT<wchar_t,class StrTraitMFC_DLL<wchar_t,class ATL::ChTraitsCRT<wchar_t> > > &)
void acedRemoveSearchPath(
