Author Topic: vla-... documentation, where can i find it?  (Read 1409 times)
andrew_nao
« on: March 16, 2012, 04:09:48 PM »
i cant seem to find this in the help files...
am i looking in the right spot?
the documentation for this type of code
Re: vla-... documentation, where can i find it?
« Reply #1 on: March 16, 2012, 04:14:15 PM »
There are no vla help docs per se. You have to use the vba help docs and translate. This may help (or not).
« Reply #2 on: March 16, 2012, 04:32:22 PM »
There's also the Visual Lisp Developer's Bible as discussed HERE
dgorsman
« Reply #3 on: March 16, 2012, 06:08:39 PM »
Something to keep in mind, is the (vla-...)/(vlax-...) syntax can apply to many different objects, not just AutoCAD ones.  For example, using dom_obj as an MSXML2 DOMDocument object then the documentElement property of that object can be accessed using (vlax-get-property dom_obj 'documentElement).
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
      {MasterBasics;}
BlackBox
« Reply #4 on: March 16, 2012, 08:57:12 PM »
Andrew - I am unsure what version you're using, but in addition to what has already been suggested, consider using the VLIDE's Apropos functionality... It's not 100%, but it can help with certain Methods/Functions again depending on your version.
Autodesk Exchange does a good adequate job of making Developer Documentation available online; sadly though the VBA documentation is not among that lot. Either keep a copy of the necessary acad_##_dev.chm (and others), or use VBAIDE docs.
HTH
