Author Topic: How to check the available Xdata space?  (Read 1489 times)
csharpbird
« on: November 14, 2011, 10:43:44 PM »
It seems that lisp has a function named xdroom which ccan get the available Xdata space.
How to do this in .NET?
fixo
Re: How to check the available Xdata space?
« Reply #1 on: November 15, 2011, 12:40:14 AM »
Not sure about it will be real size:
MessageBox.Show("Size: " + Convert.ToString(System.Runtime.InteropServices.Marshal.SizeOf(xr.Data.UnmanagedObject)))*xr* is existing dummy XRecord populated with data of 4 TypedValues(string,double)
Jeff H
« Reply #2 on: November 15, 2011, 06:18:19 AM »
Not sure if there is a .NET counterpart but maybe PInvoke acdbXdRoom?
also
acdbXdSize
