Just specify that it has to be in the AutoCAD search path and let the end-user locate it where *they* want to. You can get clever with all sorts of ways of pointing to it otherwise, from configuration files, to registry entries, to automatically adding your required folders to the end of the existing search path, to having a hard-coded program file path, but those can make life difficult for the end user.
