Hi gang,
I'm trying to write a routine that allows me to pick on an attribute (field) in a block, and create a selection set of all other blocks of that name that have the same value in that field. Make sense?
In other words I want to click on the "Species" attribute of a block called "Tree1" and I want AutoCAD to select all other "Tree1" blocks that have a similar value for "Species"
The FIND command does not seem to work because (I think) the value of the "species" attribute is a field driven by a lookup table. I believe this problem is compounded by the fact that these are dynamic blocks and once a parameter is changed, they take on a unique name...
Thanks in advance for any help.
-JP
