Author Topic: Find block attribute tag  (Read 1915 times)
Matt__W
  • I like my water diluted.
« on: September 29, 2015, 09:48:41 AM »
I've been out of the coding scene for way too long. I can't remember how to find an attribute within a block and subsequently modify it, but we'll cross that bridge when we get there. The block only has one attribute within it so that makes it easier. Here's my code so far.
  1. (defun C:BlkRotation ( / ss cnt bName assoclist blkRotation)
  2.    (setq ss (ssget '((0 . "insert")(66 . 1)((2 . "MYBLOCK"))))
  3.    (repeat (setq cnt (sslength ss))
  4.       (setq bName (ssname ss (setq cnt (1- cnt))))
  5.       (setq assoclist (entget bName))
  6.       (setq blkRotation (assoc 50 assoclist))
  7.
  8. ;;;This is where I can't remember how to find the attribute and then modify it.
  9.       (if block has attribute BLKROTATION then
  10.          (entmod block attribute value with block's actual rotation angle
  11.       ) ;end if statement...
  12.
  13.    )
  14.    (princ)
  15. )
  16.
Autodesk Expert Elite
Re: Find block attribute tag
« Reply #1 on: September 29, 2015, 11:34:50 AM »
Maybe this? FWIW .. I'd use vla-* over entmod for this task.
  1. (foreach att (vlax-invoke blkobj 'getattributes) (vla-put-rotation att blkrotation))
