Author Topic: Drawing pipe fitting - 2D  (Read 11771 times)
Kyle Reese
« on: November 03, 2008, 11:06:53 AM »
I tried to draw a 1" - 45 deg long radius welded fitting per ASA B16.9 specs I found on line.  Using the supplied centerline radius of 1.5" and knowing both the I.D. (1.049") and the O.D. (1.315") I laid out the fitting.  It seemed fine.  But when I check the distance "B" (center to face) instead of getting the .875 per the spec I get .6213.  What did I do wrong?  Anybody here deal with piping?  Thank you.
« Last Edit: November 03, 2008, 12:59:47 PM by Kyle Reese »
Re: Drawing pipe fitting - 2D
« Reply #1 on: November 03, 2008, 11:10:49 AM »
post a dimensioned drawing....and someone will tell you....
Bob Garner
« Reply #2 on: November 03, 2008, 01:22:29 PM »
I've got my Pipe Fitters Manual open to page 20 and I see the data you posted.  Got a couple of fires to put out, then I will try a layout for you.
People here are pretty exceptional so you will probably get a solution before I can get back to you.
bob g.
Bob Garner
« Reply #3 on: November 03, 2008, 05:03:02 PM »
Yeah, I see what you mean.  I laid it out and you need a 2.1124 inch radius to get the 7/8" tangent (B dimension).
Obviously I'm not a piper and I'll have to check more books at home.  My pipefitters manual shows a 1 1/2" long radius for 90 degree and 180 degree fittings but nothing for 45 degree fittings.  Are we sure the radius is supposed to be 1 1/2" for these?
Bob
Kyle Reese
« Reply #4 on: November 03, 2008, 06:16:48 PM »
I am positive.  Found it detailed this way at two different sites.  Thanks, Bob.  For a moment there I thought I had missed something.  Tried to post a .dwg but apparently I got that wrong too.
« Reply #5 on: November 03, 2008, 06:50:43 PM »
Have a look at the grips on this ... the end does NOT terminate at the tangent point ..
added:  this is a metric fitting drawn by one of my apps ... but your details are probably similar
Kyle Reese
« Reply #6 on: November 04, 2008, 01:56:29 PM »
Thanks for that reference drawing.  However, I have a fitting on my desk at the moment and I can asure you that there are no straight segments on either end.  This is not like specing out a flanged and dished head with a straight flange on it.
Bob Garner
« Reply #7 on: November 06, 2008, 09:56:11 AM »
Kyle,
Can you "reverse engineer" the elbow and give us the dimensions?
Bob
Tankman
« Reply #8 on: January 25, 2009, 08:44:18 AM »
You might like a free pipe 'n fittings, *.dwg's, free.   8-)
Try this link for a free stand alone pipe library of *.dwg files:
https://shop.charlottepipe.com/lit/category.aspx?categoryid=26&openid=26
Krushert
  • FREE BEER Tomorrow!!
« Reply #9 on: January 26, 2009, 10:26:22 AM »
Thanks for the link.
t-bear
« Reply #10 on: January 26, 2009, 12:56:41 PM »
We use tons of stainless weld elbows, tees etc. here and I've checked some 1" 45 degree elbows.  They all come out at 7/8" center to face, and all have about a 1/4" straight section on both faces.  For kicks and grins, I had the shop cut a 90 degree elbow in half....one face measured 7/8" cen-to-face, and the "cut" face measured 5/8" cen-to-face, leading me to believe that there actually is a straight section on 45 degree elbows.
Tankman
« Reply #11 on: February 19, 2009, 02:44:47 PM »
Glad to be of some help. The freebie is well worth adding to your piping library.   :-)
Tankman
« Reply #12 on: August 09, 2009, 09:24:33 AM »
Could the two different measurements, 7/8" and 5/8", been the result of the saw blade thickness?
Never tried sawing the fitting we're discussing but, ANSI fitting dimensions are right on.
Tankman
« Reply #13 on: September 23, 2009, 07:23:02 PM »
Has anyone received their CD from Charlotte Pipe?
Looking for opinions. What do you think.
« Reply #14 on: September 24, 2009, 09:30:32 PM »
See if this helps ...
This Is the basis for formula I use.
