Author Topic: Plot to PDF with layout tab name  (Read 1846 times)
T-Square
« on: September 19, 2009, 03:00:00 PM »
Hello,
I am trying to plot multiple tabs to individual pdf files. I am using a plot tabs routine to plot to a pre-configured pdf page setup.
When I plot the tabs it asks for a file name. I have to manually enter the name for each tab. Anyone know of a way I can have the output file name match the tab name?
I am using CutePDF to create the pdf files.
Thanks in advance.
Re: Plot to PDF with layout tab name
« Reply #1 on: September 19, 2009, 03:28:02 PM »
You can get the latest version  here
http://www.theswamp.org/index.php?topic=1916.0
I think that was requested before & I could find no solution but I'll look again.
PS the DCL file is created by the LISP. This feature was added in 2004.
« Reply #2 on: September 19, 2009, 04:28:25 PM »
This is what I use http://www.pdf995.com/why.html
Cost is $10.00 & it allows automatic file names. I got the suite for $20.00
« Last Edit: September 19, 2009, 04:31:29 PM by CAB »
T-Square
« Reply #3 on: September 20, 2009, 11:59:32 AM »
Cab,
Thanks for the post.
Here is what I ended up doing.
I used the publish feature to plot to a DWF file. Which contains all of the tabs... the tabs I want that is.
Then I open the DWF file in Design Review(2008) and then plot to a pdf.
Works pretty well.
I have the pdf995 driver installed. I think it came with some tax software.
Round about way of getting this done, but it works. :-)
