Author Topic: Lisp error  (Read 3186 times)
One Shot
Lisp error
« on: August 30, 2005, 05:01:50 PM »
I am trying to find the error in this lisp.  It happens at the blockit function.  Can someone please point it out to me and tell me what I need to do to fix it.
Thank you
(defun C:WINTRIM ( / *error* stq wq pick1 pick2 pick3 pick4 tpnt1 tpnt2 bpnt)
  (setvar "cmdecho" 0)
  (setq o_osmode (getvar "osmode")
   o_clayer (getvar "clayer")
   *error*  sillerr
        blss     nil
  (if (not stype) (setq stype "TS"))
  (if (not width) (setq width 3))
  (prompt "\nType: TS-Trim Sill/TSS-Trim Sill Surround/BS-Brick Surround/BR-Brick Rowlock")
  (initget "TS TSS BS BR")
  (if (/= (setq stq (getkword (strcat "\nSpecify type [TS/TSS/BS/BR]<" stype ">: "))) nil)
    (setq stype stq)
  (initget "3 4 6 8")
  (if (/= (setq wq (getkword (strcat "\nSpecify width [3/4/6/8]<" (itoa width) ">: "))) nil)
    (setq width (atoi wq))
    ((= stype "TS")
      (initget 1)
      (setq pick1 (getpoint "\nSelect left corner: "))
      (initget 1)
      (setq pick2 (getpoint pick1 "\nSelect right corner: "))
      (setq tpnt1 (polar pick1 (angle pick2 pick1) 0.75)
        tpnt2 (polar pick2 (angle pick1 pick2) 0.75)
       bpnt  (polar pick1 (angle pick1 pick2) (/ (distance pick1 pick2) 2))
      (drawit stype tpnt1 tpnt2 width nil)
      (blockit stype tpnt1 tpnt2 bpnt width nil blss)
    ((= stype "TSS")
      (initget 1)
      (setq pick1 (getpoint "\nSelect top left corner: "))
      (initget 1)
      (setq pick2 (getpoint pick1 "\nSelect bottom left corner: "))
      (initget 1)
      (setq pick3 (getpoint pick2 "\nSelect bottom right corner: "))
      (initget 1)
      (setq pick4 (getpoint pick3 "\nSelect top right corner: "))
      (setq tpnt1 (polar pick2 (angle pick3 pick2) (+ width 0.75))
        tpnt2 (polar pick3 (angle pick2 pick3) (+ width 0.75))
       bpnt  (polar pick1 (angle pick1 pick4) (/ (distance pick1 pick4) 2))
      (drawit stype pick1 pick2 width nil)
      (drawit stype pick3 pick4 width nil)
      (blockit stype tpnt1 tpnt2 bpnt width (+ (distance pick1 pick2) width) blss)
    ((= stype "BR")
      (initget 1)
      (initget 1)
      (setq bpnt  (polar pick1 (angle pick1 pick2) (/ (distance pick1 pick2) 2)))
      (drawit stype pick1 pick2 width 2.750)
      (blockit stype pick1 pick2 bpnt width nil blss)
    ((= stype "BS")
      (initget 1)
      (initget 1)
      (initget 1)
      (initget 1)
      (setq tpnt1 (polar pick2 (angle pick3 pick2) width)
        tpnt2 (polar pick3 (angle pick2 pick3) width)
      (drawit stype pick1 pick2 width 3.0)
      (drawit stype tpnt1 tpnt2 width 2.750)
      (drawit stype pick3 pick4 width 3.0)
  (setvar "clayer" o_clayer)
  (setvar "osmode" o_osmode)
  (setvar "cmdecho" 1)
;Draw Routine
(defun drawit (typ pt1 pt2 wdth lnspac / reclgth ang pt3 pt4 realnum remain
                                    intnum offset lnpt1 lnpt2
  (setq reclgth (distance pt1 pt2)
   ang     (angle pt1 pt2)
        pt3     (polar pt1 (- ang (/ pi 2)) wdth)
   pt4     (polar pt2 (- ang (/ pi 2)) wdth)
  (setvar "clayer" "0")
  (setvar "plinewid" 0)
  (setvar "osmode" 0)
  (command "-color" 6 "-linetype" "Set" "ByBlock" "")
  (command "_.pline" pt1 pt3 pt4 pt2 "C")
  (if (not blss) (setq blss (ssadd (entlast))) (ssadd (entlast) blss))
  (if (/= lnspac nil)
      (setq realnum (rtos (/ reclgth lnspac) 2 8))
      (setq remain (distof (substr realnum (+ (vl-string-search "." realnum) 1)) 2))
      (if (>= remain 0.53125)
        (setq intnum (+ (atoi realnum) 1))
        (setq intnum (atoi realnum))
      (setq offset (/ (- reclgth (* intnum lnspac)) 2))
      (setq offset (+ lnspac offset))
      (command "-color" 1)
      (repeat (- intnum 1)
        (setq lnpt1 (polar pt1 ang offset))
        (setq lnpt2 (polar pt3 ang offset))
        (command "_.line" lnpt1 lnpt2 "")
      (command "-color" "ByLayer" "-linetype" "Set" "ByLayer" "")
;Block Routine
(defun blockit (typ pt1 pt2 basept wdth hgt ss / )
  (setvar "filedia" 1)
  (if (/= hgt nil)
    (setq blk_name (strcat (itoa wdth) typ "-" (rtos (distance pt1 pt2) 2 1) " X " (rtos hgt 2 1) ".dwg"))
    (setq blk_name (strcat (itoa wdth) typ "-" (rtos (distance pt1 pt2) 2 1) ".dwg"))
  C:\Documents and Settings\bcrouse\Desktop\Library R & D Blocks\Window Trim" blk_name))
  (command "_.move" ss "" basept "0,0,0")
  (if (/= (findfile path) nil)
    (command "_.-wblock" path "Y" "" "0,0,0" ss "")
    (command "_.-wblock" path "" "0,0,0" ss "")
  (command "_.-insert" path "S" 1 basept 0)
;Error Routine
(defun sillerr (msg)
  (prompt (strcat "\nError: " msg))
)[/code]
Lisp error
« Reply #1 on: August 30, 2005, 05:07:07 PM »
If this line (defun blockit ... ) counts as line number 1, I'd say there's something screwy with line number 7 (starts with C:\Documents ...), for starters.
i.e. not quoted, single backslashes ...
One Shot
Lisp error
« Reply #2 on: August 30, 2005, 05:38:02 PM »
Okay I got it to work.  Why would I get this for the name of block (Documents and SettingsbcrouseDesktopLibrary R & D BlocksWindow Trim4BS-41.6 X 80.8.dwg)
I just to want to get the block name:
Example: 4BS-41.6 X 80.8.dwg
;Block Routine
  (if (/= hgt nil)
  (setq path (strcat "C:\Documents and Settings\bcrouse\Desktop\Library R & D Blocks\Window Trim" blk_name))
;Error Routine
I would like to have it to work like this example of a lisp:
Example:
(if (tblsearch "BLOCK" BLOCK-NAME)
    (setq ANSWER (KWORD_PROMPT (list "Yes" "No") "Redefine Block" 1))
  (setvar "osmode" 0)
  (if (or (not (tblsearch "BLOCK" BLOCK-NAME))
 (= "Yes" ANSWER)
((= ARCH-TYPE "4CK")
(setq COURSE 10.75
      BOTTOM 4.0
      TOP 8.5
      HEIGHT 13.75
      PT-LIST (COURSE-CALC PT-LIST COURSE)
      KEY-LIST (KEY-CALC PT-LIST BOTTOM TOP HEIGHT)
((= ARCH-TYPE "4C")
(setq COURSE 10.75
      KEY-LIST NIL
((= ARCH-TYPE "3CK")
(setq COURSE 8.0
      BOTTOM 4.0
      TOP 8.5
      HEIGHT 10.625
((= ARCH-TYPE "3C")
(setq COURSE 8.0
      KEY-LIST NIL
      (setq SDLIST (SOLDIER-CALC PT-LIST KEY-LIST BRICK))
      (setq SSLIST (DRAWJACK PT-LIST KEY-LIST ARCH-TYPE))
      (if (= ANSWER "Yes")
(command "-block" BLOCK-NAME ANSWER BLOCK-INS SSLIST SDLIST "")
(command "-block" BLOCK-NAME BLOCK-INS SSLIST SDLIST "")
    (command "-insert" BLOCK-NAME BLOCK-INS 1 1 0)
  (setq SUPPORT-FOLDER (getvar "dwgprefix")
;; currently set to the current drawings folder
BLOCK-FILENAME (strcat SUPPORT-FOLDER BLOCK-NAME ".dwg")
  (if (not (findfile BLOCK-FILENAME))
    (command "-wblock" BLOCK-FILENAME BLOCK-NAME)
      (prompt "\nFile already exists.")
(= (setq
    ANSWER (KWORD_PROMPT (list "Yes" "No") "Redefine file?" 1)
  "Yes"
(command "-wblock" BLOCK-FILENAME ANSWER BLOCK-NAME)
  (RETVARS)
How would I do that?
Thank you,
Brad
Jim Yadon
Lisp error
« Reply #3 on: August 30, 2005, 06:59:11 PM »
Quote from: One Shot
;Block Routine
  (if (/= hgt nil)
;Error Routine
If you cut the strcat function with the file path it'll give you what you're after I believe. I don't have time to test it for you at the moment, my dinner is nearly ready.
Bob Wahr
Lisp error
« Reply #4 on: August 30, 2005, 07:14:13 PM »
shouldn't
be
 (setq   path (strcat "C:\\Documents and Settings\\bcrouse\\Desktop\\Library R & D Blocks\\Window Trim\\" blk_name))
or
 (setq   path (strcat "C:/Documents and Settings/bcrouse/Desktop/Library R & D Blocks/Window Trim/" blk_name)) Mind you, my lisp is horrible but it seems like I remember something like that.
Lisp error
« Reply #5 on: August 30, 2005, 08:37:57 PM »
Some other items to look at.
Another way to build the block name.
Here (if (findfile path) returns a non nil and has the same result as (if (/= (findfile path) nil)
You may want to consider a global variable *rootpath*
(setq *rootpath* "C:/Documents and Settings/bcrouse/Desktop/Library R & D Blocks/")
then
  (setq path (strcat *rootpath* "Window Trim/" blk_name))
Just some things to consider.
Yes Bob is correct.
;Block Routine
  (setq blk_name
             (if (/= hgt nil)
              (strcat " X " (rtos hgt 2 1) ".dwg")
               ".dwg"
  (if (findfile path)
One Shot
Lisp error
« Reply #6 on: August 31, 2005, 08:32:46 AM »
Quote from: Bob Wahr
shouldn't
be
or
Thank you for your help!
One Shot
Lisp error
« Reply #7 on: August 31, 2005, 11:55:34 AM »
Thank you CAB.  How have you been?  How has the fishing been going for you?
Brad
Lisp error
« Reply #8 on: August 31, 2005, 12:01:12 PM »
Been good, was in the Keys for two weeks 4-18 but the legal size lobster were scarce this year.
Saw you e-mail but was too busy getting my feet back on the ground after vacation.
Forgot about it until I saw your post. Hope you got it worked out.
See Ya..
One Shot
Lisp error
« Reply #9 on: August 31, 2005, 12:03:31 PM »
Quote from: CAB
See Ya..
I have tried it out and it still is not working right.  By the way, I will be down in the Sunshine State for AU this year.  Hope to see you there if you go?
Brad
