Author Topic: [Solved] INI-file: create paths with strcat ..  (Read 1909 times)
Peter2
« on: December 12, 2014, 05:31:23 AM »
Maybe a crazy idea or a "challenge" - please don't invest too much time in it ...
EDIT:
neither "crazy" nor "challenge" - "read" is the solution
At the moment, I set paths inside Lisp:
setq mainpath "d:\\cad\\test\\"
      lisppath (strcat systempfad="Lisp_Dbx_Arx\\")
Now I have to migrate these settings to an ini-file and to read it with "dos_getini".
Here is the  current state-of-the-art - INI-file:
[Paths]
mainpath=d:\cad\test\
lisppath=d:\cad\test\Lisp_Dbx_Arx\
Of course an INI is "hardcoded" - when I change the mainpath all other paths have to be changed too. And of course that's not a real problem - search and replace with editor. Or use for the "strcat" inside lisp to concatenate the info.
But -  how about writing the lisp-commands to the INI and read and use them:
[Paths]
lisppath=(strcat mainpath "\\Lisp_Dbx_Arx\")
It's no problem to read the values, but of course the result is a string. So the main question is:
How to use a string as command?
Thanks and regards
« Last Edit: December 12, 2014, 05:57:21 AM by Peter2 »
Peter
BricsCAD V23
Re: INI-file: create paths with strcat ..
« Reply #1 on: December 12, 2014, 05:44:22 AM »
Perhaps something like :
  1.
  2. (setq mainpath   "d:\\cad\\test\\"
  3.       secondpath "Lisp_Dbx_Arx\\"
  4. )
  5.
  6. (setq xxxx "(strcat mainpath secondpath))")
  7.
  8.
  9. (eval (read xxxx))
  10.
  11.
Peter2
« Reply #2 on: December 12, 2014, 05:56:07 AM »
Oh - "read" is the key. Never used it  :embarrassed:
Thanks Kerry, have a fine weekend.
Peter
BricsCAD V23
« Reply #3 on: December 12, 2014, 06:05:32 AM »
I shall.
