Author Topic: Split String With String  (Read 6189 times)
Grrr1337
« on: June 09, 2017, 02:01:06 PM »
Hi guys,
 I've wrote this to handle easier some string manipulation:
  1. ; SplitStr - String used to split
  2. ; TotalStr - total string
  3. ; This is whats supposed to do [the delimiter is a string, not a character]:
  4. ; (SplitStrWithStr "ABC" "HESJAABCHJE SAABCHJEWABC") -> '("HESJA" "ABC" "HJE SA" "ABC" "HJEWABC")
  5. (defun SplitStrWithStr ( SplitStr TotalStr / i->L TrimListFrom stringp L n Nths r sL nStr wait r1 r2 itm rr LastS tmp )
  6.
  7.   (defun i->L ( i / L ) (repeat i (setq L (cons (setq i (1- i)) L))) (reverse L))
  8.   (defun TrimListFrom ( n L ) (repeat n (setq L (cdr L))) L)
  9.   (defun stringp ( s ) (eq 'STR (type s)))
  10.
  11.   (setq L (mapcar 'chr (vl-string->list TotalStr)))
  12.   (setq n (strlen SplitStr))
  13.   (setq Nths (i->L n))
  14.   (while L
  15.     (and
  16.       (setq sL (reverse (vl-remove-if-not 'stringp (mapcar (function (lambda (x) (nth x L))) Nths))))
  17.       (setq nStr (apply 'strcat sL))
  18.       (cond ; "nStr" - constantly changing string with length equal to the "SplitStr"
  19.         ( (= SplitStr nStr)
  20.           (and itm (setq r (cons (apply 'strcat (vl-remove-if-not 'stringp (reverse itm))) r)) (setq itm nil))
  21.           (setq r (cons nStr r))
  22.           (setq L (TrimListFrom n L)) ; Skip it
  23.           (and
  24.             (setq tmp (vl-remove-if-not 'stringp L)) ; _$ (apply 'strcat nil) -> ""
  25.             (setq tmp (apply 'strcat tmp))
  26.             (setq LastS tmp)
  27.           ); and
  28.         )
  29.         (T
  30.           (setq itm (cons (car L) itm))
  31.           (setq L (cdr L)) ; Process one by one
  32.         ); T
  33.       ); cond
  34.     ); and
  35.   ); while
  36.   (append (reverse r) (if LastS (list LastS)))
  37. ); defun
  38.
It should split the TotalStr, using a SplitStr and retain the SplitStr positions.
The problem is that if the last pattern is the SplitStr, it duplicates and fks up the result:
; _$ (SplitStrWithStr "$#*" "$#*ABC$#*")
; ("$#*" "ABC" "$#*" "ABC$#*")
; _$ (SplitStrWithStr "$#*" "$#*ABC")
; ("$#*" "ABC")
; _$ (SplitStrWithStr "$#*" "ABC$#*")
; ("ABC" "$#*")
; _$ (SplitStrWithStr "$#*" "$#*ABC$#*DEF$#*GHIJKL$#*MNOP$#*")
; ("$#*" "ABC" "$#*" "DEF" "$#*" "GHIJKL" "$#*" "MNOP" "$#*" "MNOP$#*")
; _$ (SplitStrWithStr "$#*" "ABC$#*DEF$#*GHIJKL$#*MNOP")
; ("ABC" "$#*" "DEF" "$#*" "GHIJKL" "$#*" "MNOP")
; _$
The returns should be as follow:
; ("$#*" "ABC" "$#*")
; ("$#*" "ABC")
; ("ABC" "$#*")
; ("$#*" "ABC" "$#*" "DEF" "$#*" "GHIJKL" "$#*" "MNOP" "$#*" "MNOP" "$#*")
; _$
As you can see this is not a standard "split-string" function, that uses a letter/character delimeter, but a whole string instead.  :idea:
(apply ''((a b c)(a b c))
vevo.bg
Re: Split String With String
« Reply #1 on: June 09, 2017, 03:03:17 PM »
Here's a quick kludge :)
  1. (defun _foo (p s / i out)
  2.     (progn (while (setq i (vl-string-search p s))
  3.         (setq out (cons (list (substr s 1 i) p) out))
  4.         (setq s (substr s (+ 1 (strlen p) i)))
  5.       )
  6.       (vl-remove "" (append (apply 'append (reverse out)) (list s)))
  7.     )
  8.   )
  9. )
  10. (_foo "$#*" "$#*ABC$#*")
  11. (_foo "$#*" "$#*ABC")
  12. (_foo "$#*" "ABC$#*")
  13. (_foo "$#*" "$#*ABC$#*DEF$#*GHIJKL$#*MNOP$#*")
  14. (_foo "$#*" "ABC$#*DEF$#*GHIJKL$#*MNOP")
  15. ;;;_$
  16. ;;;_FOO
  17. ;;;("$#*" "ABC" "$#*")
  18. ;;;("$#*" "ABC")
  19. ;;;("ABC" "$#*")
  20. ;;;("$#*" "ABC" "$#*" "DEF" "$#*" "GHIJKL" "$#*" "MNOP" "$#*")
  21. ;;;("ABC" "$#*" "DEF" "$#*" "GHIJKL" "$#*" "MNOP")
  22. ;;;_$
  23.
« Last Edit: June 09, 2017, 03:12:39 PM by ronjonp »
Grrr1337
« Reply #2 on: June 09, 2017, 03:32:21 PM »
 Wow, Ron! You are such a ninja! :yay!:
Anyway to reveal what were my ideas/intentions:
1. Some improvement on the algorithm of this thing [it was searching for a pattern of 7 characters (a b c d e f g)]
2. Obviously easy manipulation of the text content from an external file (referring more about DCL),
 which means that (set_attr) function can be created by reloading the dialog - no idea where it would be useful, but why limit ourselves?
 :idea:
vevo.bg
Marc'Antonio Alessi
  • Marco
« Reply #3 on: June 10, 2017, 05:56:35 PM »
My version (I have modified an old function):
(defun ALE_String2ListWStrDlm (InpStr StrDlm / SttPos TmpPos DlmLng TmpLst TmpStr)
    ( (/= (type InpStr) (type StrDlm) 'STR) )
    ( (= InpStr StrDlm) '("") )
    (T
      (setq
        DlmLng (strlen StrDlm)   SttPos 0
        TmpPos (vl-string-search StrDlm InpStr SttPos)
      (while TmpPos
        (if (zerop (- TmpPos SttPos))
          (setq TmpLst  (cons StrDlm TmpLst))
          (setq TmpLst (cons StrDlm (cons (substr InpStr (1+ SttPos) (- TmpPos SttPos)) TmpLst)))
        (setq
          SttPos (+ TmpPos DlmLng)
      (if (= "" (setq TmpStr (substr InpStr (1+ SttPos))))
        (reverse TmpLst)
        (reverse (cons TmpStr TmpLst))
(ALE_String2ListWStrDlm "$#*ABC$#*" "$#*") => ("$#*" "ABC" "$#*")
(ALE_String2ListWStrDlm "$#*ABC" "$#*") => ("$#*" "ABC")
(ALE_String2ListWStrDlm "ABC$#*" "$#*") => ("ABC" "$#*")
(ALE_String2ListWStrDlm "$#*ABC$#*DEF$#*GHIJKL$#*MNOP$#*" "$#*") => ("$#*" "ABC" "$#*" "DEF" "$#*" "GHIJKL" "$#*" "MNOP" "$#*")
(ALE_String2ListWStrDlm "ABC$#*DEF$#*GHIJKL$#*MNOP" "$#*") => ("ABC" "$#*" "DEF" "$#*" "GHIJKL" "$#*" "MNOP")
gile
  • Marseille, France
« Reply #4 on: June 10, 2017, 06:38:29 PM »
  1. (defun foo (pat str / pos)
  2.   (cond
  3.     ((= str "") nil)
  4.     ((not (setq pos (vl-string-search pat str))) (list str))
  5.     ((zerop pos) (cons pat (foo pat (substr str (1+ (strlen pat))))))
  6.     ((cons (substr str 1 pos) (foo pat (substr str (1+ pos)))))
  7.   )
  8. )
« Last Edit: June 10, 2017, 06:52:27 PM by gile »
Marc'Antonio Alessi
  • Marco
« Reply #5 on: June 11, 2017, 03:43:08 PM »
  ; 20170611 - version 1.01 - just a little improvement
    ( (= InpStr StrDlm) (list InpStr) )
    (T
      (setq DlmLng (strlen StrDlm)   SttPos 0)
      (if (zerop (setq TmpPos (vl-string-search StrDlm InpStr SttPos)))
        (setq
          TmpLst (cons StrDlm TmpLst)     SttPos DlmLng
      (while TmpPos
        (setq
        (reverse TmpLst)
Grrr1337
« Reply #6 on: June 11, 2017, 04:09:40 PM »
Thanks for the input guys!
I see that the main drawback in my code was avoiding the (vl-string-search) function, and rely on list iteration (not string iteration).
vevo.bg
« Reply #7 on: June 11, 2017, 04:22:32 PM »
Another variation:
  1. (defun split ( s p / i )
  2.     (if (/= "" s)
  3.         (if (setq i (vl-string-search p s))
  4.             (append (split (substr s 1 i) p) (list p) (split (substr s (+ (strlen p) i 1)) p))
  5.             (list s)
  6.         )
  7.     )
  8. )
Marc'Antonio Alessi
  • Marco
« Reply #8 on: June 13, 2017, 03:29:20 PM »
(defun ALE (s d / p m l o r)
  ; version for Speed Test
    ( (= s d) (list s) )
    ( (setq l (strlen d))
      (if (zerop (setq m (vl-string-search d s 0)))
        (setq
          o (cons d o)     p l
          m (vl-string-search d s p)
        (setq p 0)
      (while m
        (setq
          o (cons d (cons (substr s (1+ p) (- m p)) o))
          p (+ m l)
      (if (= "" (setq r (substr s (1+ p))))
        (reverse o)
        (reverse (cons r o))
(setq Keys "$#*" String "$#*ABC$#*DEF$#*GHIJKL$#*MNOP$#*")
Benchmark.lsp | © 2005 Michael Puckett | All Rights Reserved
Elapsed milliseconds / relative speed for 131072 iteration(s):
    (ALE STRING KEYS)..........1609 / 1.48 <fastest>
    (_FOO_RON KEYS STRING).....2203 / 1.08
    (SPLIT STRING KEYS)........2250 / 1.06
    (FOO_GILE KEYS STRING).....2375 / 1 <slowest>
« Reply #9 on: June 13, 2017, 04:05:20 PM »
Interesting .. I come up with completely different results:
SPLIT Benchmarking ...................Elapsed milliseconds / relative speed for 65536 iteration(s):
    (SPLIT "$#*" "$#*ABC$#*DEF$#*GHIJKL$...).....1562 / 1.75 <fastest>
    (ALE_STRING2LISTWSTRDLM "$#*" "$#*AB...).....1797 / 1.52
    (_FOO "$#*" "$#*ABC$#*DEF$#*GHIJKL$#...).....2547 / 1.07
    (FOO "$#*" "$#*ABC$#*DEF$#*GHIJKL$#*...).....2735 / 1.00 <slowest>
; 10 forms loaded from #<editor "<Untitled-4> loading...">
_$
Marc'Antonio Alessi
  • Marco
« Reply #10 on: June 13, 2017, 04:45:18 PM »
Interesting .. I come up with completely different results:...
Strange:
(Benchmark '(
(_foo Keys String)
(foo  Keys String)
(split String Keys)
(ALE String Keys)
(_foo Keys String)
(foo  Keys String)
(split String Keys)
(ALE String Keys)
    (ALE STRING KEYS).......1688 / 1.65 <fastest>
    (ALE STRING KEYS).......1719 / 1.62
    (_FOO KEYS STRING)......2562 / 1.09
    (SPLIT STRING KEYS).....2625 / 1.06
    (_FOO KEYS STRING)......2656 / 1.05
    (FOO KEYS STRING).......2656 / 1.05
    (SPLIT STRING KEYS).....2718 / 1.02
    (FOO KEYS STRING).......2782 / 1 <slowest>
    (ALE STRING KEYS).......1641 / 1.59 <fastest>
    (ALE STRING KEYS).......1718 / 1.52
    (FOO KEYS STRING).......2515 / 1.04
    (_FOO KEYS STRING)......2532 / 1.03
    (FOO KEYS STRING).......2532 / 1.03
    (_FOO KEYS STRING)......2547 / 1.02
    (SPLIT STRING KEYS).....2609 / 1
    (SPLIT STRING KEYS).....2610 / 1 <slowest>
Marc'Antonio Alessi
  • Marco
« Reply #11 on: June 13, 2017, 04:52:24 PM »
Ok... take look at the arguments:
(_foo  Keys String)
(foo   Keys String)
(split String Keys)
(ALE   String Keys)
gile
  • Marseille, France
« Reply #12 on: June 13, 2017, 05:02:19 PM »
If speed is the goal, this one should be a little more efficient
  2.   (cond
  3.     ((= str "") nil)
  6.     ((vl-list* (substr str 1 pos) pat (foo pat (substr str (+ 1 (strlen pat) pos)))))
  7.   )
  8. )
$ (benchmark
  '((ALE_String2ListWStrDlm "$#*ABC$#*DEF$#*GHIJKL$#*MNOP$#*" "$#*")
    (ALE "$#*ABC$#*DEF$#*GHIJKL$#*MNOP$#*" "$#*")
    (split "$#*ABC$#*DEF$#*GHIJKL$#*MNOP$#*" "$#*")
    (foo "$#*" "$#*ABC$#*DEF$#*GHIJKL$#*MNOP")
    (ALE "$#*ABC$#*DEF$#*GHIJKL$#*MNOP$#...).....1435 / 1.51 <fastest>
    (ALE_STRING2LISTWSTRDLM "$#*ABC$#*DE...).....1576 / 1.38
    (FOO "$#*" "$#*ABC$#*DEF$#*GHIJKL$#*...).....1576 / 1.38
    (SPLIT "$#*ABC$#*DEF$#*GHIJKL$#*MNOP...).....2060 / 1.05
    (_FOO "$#*" "$#*ABC$#*DEF$#*GHIJKL$#...).....2168 / 1 <slowest>
Marc'Antonio Alessi
  • Marco
« Reply #13 on: June 13, 2017, 05:14:29 PM »
Yes is faster, my test:
    (ALE STRING KEYS).......1656 / 1.56 <fastest>
    (ALE STRING KEYS).......1703 / 1.51
    (FOO KEYS STRING).......2000 / 1.29
    (_FOO KEYS STRING)......2516 / 1.02
    (_FOO KEYS STRING)......2531 / 1.02
    (SPLIT STRING KEYS).....2562 / 1.01
    (SPLIT STRING KEYS).....2578 / 1 <slowest>
    (ALE STRING KEYS).......1688 / 1.52 <fastest>
    (ALE STRING KEYS).......1719 / 1.49
    (FOO KEYS STRING).......1969 / 1.3
    (FOO KEYS STRING).......2000 / 1.28
    (_FOO KEYS STRING)......2515 / 1.02
    (SPLIT STRING KEYS).....2532 / 1.01
    (SPLIT STRING KEYS).....2562 / 1 <slowest>
Marc'Antonio Alessi
  • Marco
« Reply #14 on: June 13, 2017, 05:37:54 PM »
Found a little bug:
  ; 20170613 - version 1.02
    ( (setq l (strlen d)  m (vl-string-search d s 0))
      (if (zerop m)
        (setq
          o (cons d o)     p l
        (setq p 0)
      (while m
        (setq
          p (+ m l)
        (reverse o)
    ( (list s) )
gile
  • Marseille, France
« Reply #15 on: June 13, 2017, 07:00:37 PM »
Talking about speed.
A simple F# implementation:
Code - F#: [Select]
  1. open System.Text.RegularExpressions
  2.
  3. let foo pat str =
  4.     let rec loop acc = function
  5.         | [] | [""] -> List.rev acc
  6.         | [s]       -> List.rev (s :: acc)
  7.         | "" :: l   -> loop (pat :: acc) l
  8.         | s :: l    -> loop (pat :: s :: acc) l
  9.     Regex.Split(str, Regex.Escape(pat))
  10.     |> Array.toList
  11.     |> loop []
A little bench for 65536 iterations give results about 10 times faster than AutoLISP
Code - F#: [Select]
  1. let bench () =
  2.     let sw = System.Diagnostics.Stopwatch()
  3.     sw.Start()
  4.     for i in 0..65535 do
  5.         foo "$#*" "$#*ABC$#*DEF$#*GHIJKL$#*MNOP$#*" |> ignore
  6.     sw.Stop()
  7.     printfn "Elapsed milliseconds for 65536 iterations: %d" sw.ElapsedMilliseconds
> bench ();;
Elapsed milliseconds for 65536 iterations: 123
val it : unit = ()
EDIT: I was tired last night, Regular Expression can do it quite directly:
Code - F#: [Select]
  1. let foo pat str =
  2.     Regex.Split(str, "(" + Regex.Escape(pat) + ")")
  3.     |> Array.filter(fun s -> s <> "")
« Last Edit: June 14, 2017, 06:14:36 AM by gile »
« Reply #16 on: June 13, 2017, 11:29:55 PM »
(_foo  Keys String)
(foo   Keys String)
(split String Keys)
(ALE   String Keys)
I see that now .. guess I should not assume that initial form would follow in testing.
Marc'Antonio Alessi
  • Marco
« Reply #17 on: June 14, 2017, 08:45:33 AM »
About recursion, with long string we can see more differences:
(repeat 8 (setq String (strcat String Keys String))) ; la ricorsione arriva fino a 11
(print (strlen String))
Comando: (strlen String)
8701
Elapsed milliseconds / relative speed for 1024 iteration(s):
    (ALE STRING KEYS).....1531 / 4.34 <fastest>
    (FOO KEYS STRING).....6547 / 1.01
    (FOO KEYS STRING).....6641 / 1 <slowest>
VovKa
  • Ukraine
« Reply #18 on: June 14, 2017, 09:30:45 AM »
Interesting enough I fixed the benchmark and Lee's split is still the fastest?
you've switched the arguments in Lee's function only once, but should've done it thrice :)
gile
  • Marseille, France
« Reply #19 on: June 14, 2017, 09:34:40 AM »
ronjonp,
It looks like you have a wrong version of the 'split' routine.
With the version you psted
  1. _$ (split "$#*" str)
returns ("" "$#*" "$#*")
Before hunting milliseconds with benchmarks, we should make sure that the routines work as expected.
« Reply #20 on: June 14, 2017, 10:18:40 AM »
DOH!  :)
Marc'Antonio Alessi
  • Marco
« Reply #21 on: June 15, 2017, 10:01:36 AM »
Tested on Bricscad V17, recursion is very slow:
(setq Keys "$#*" String "$#*$#*ABC$#*DEF$#*$#*GHIJKL$#*MNOP$#*$#*")
(repeat 6 (setq String (strcat String Keys String)))
(print (strlen String)) (princ " strlen\n")
2749  strlen
Elapsed milliseconds / relative speed for 16384 iteration(s):
    (ALE STRING KEYS)......2938 / 11.89 <fastest>
    (FOO KEYS STRING).....34922 / 1 <slowest>
...another bug with adjacent key, similar my first version:
  ; 20170614 - version 1.03 for adjacent key (d)
    ( (setq
        l (strlen d)          p 0
      (while m
        (if (zerop (- m p))
          (setq o (cons d o))
          (setq o (cons d (cons (substr s (1+ p) (- m p)) o)))
        (setq
          p (+ m l)
        (reverse o)
    ( (list s) )
