Author Topic: Simple question (indefinite points)  (Read 12092 times)
Re: Simple question (indefinite points)
« Reply #45 on: October 18, 2007, 07:05:38 PM »
Once you start, you won't want to stop.  You will see all these little things that you do, and could be automated to save a couple of keystrokes per usage, and you will automate it.  Happened to us all!  And each one of us had to start somewhere.
Welcome to the Swamp Robert!
« Reply #46 on: October 18, 2007, 10:01:15 PM »
so what's the code for turning ortho off?
(setq user_ortho (getvar "orthomode"))
  (setvar "orthomode" 0)
Or am I not understanding something right?
Try this on for size. There are several variations of this but this one will serve you good for now.
[ http://www.theswamp.org/index.php?topic=51.0#top ]
Notsober
« Reply #47 on: October 24, 2008, 09:10:08 AM »
I hate rehashing an OLD thread... but this is where I got started in the swamp... thanks to Kate  :wink:
but, I have another question about this lisp routine.
Often when I use it, I'm in the middle of the routine and if I find that i've messed up the spline, I hit ESC - all my osnap settings reset - grrrr!
how do I write an error function, to the affect that I can make sure my osnap settings never reset. dang I hate that!
hmspe
« Reply #48 on: October 24, 2008, 09:50:52 AM »
I'd suggest doing a search here for "error handler".  There's lots of information.  The first thread returned (started by alanjt) should point you in the right direction.  CAB's routine in post #2 would do what you want.  You'd need to change variable names -- you use 'user_os' while CAB has used 'useros'.  You'd also want to reset clayer and orthomode.  CAB's routine resets cmdecho, which you don't have in your routine.
Martin
Notsober
« Reply #49 on: October 24, 2008, 09:53:26 AM »
thanks for the reply.
i'll go looky...
Notsober
« Reply #50 on: October 24, 2008, 10:05:00 AM »
okay... plz help a lispidiot...
do I paste this code just anywhere within my revspline.lsp routine using notepad like this...
(defun C:RS (/ user_layer user_os user_ortho)
  (setq user_layer (getvar "clayer"))
    (setvar "clayer" "Dimensions")
  (setq user_os (getvar "osmode"))
    (setvar "osmode" 0)
  (command "_.spline")
  (while (> (getvar "CmdActive") 0)
    (command pause)
  (command "_.revcloud" "o" "l" "n")
  (setvar "clayer" user_layer)
  (setvar "osmode" user_os)
  (setvar "orthomode" user_ortho)
  (defun *error* (msg)
    (if (not
          (member msg  '("console break" "Function cancelled" "quit / exit abort" "")))
    ) ; if
    (and user_layer (setvar "clayer" user_layer))
    (and user_os (setvar "osmode" user_os))
    (and user_ortho (setvar "orthomode" user_ortho))
  ) ; end error function
or what?
Alan Cullen
« Reply #51 on: October 24, 2008, 10:13:57 AM »
Just my two bobs worth....but place your error handler above the main code...I will continue to look at your code and get back to you.
Alan Cullen
« Reply #52 on: October 24, 2008, 10:19:43 AM »
Just a minor thought........but why are you trying to capture variables that are not being changed in the lisp....
Everything seems to hinge around this line of code.......
I haven't tested it, so I can't really say, just seems odd. What are you trying to do?
Notsober
« Reply #53 on: October 24, 2008, 10:33:49 AM »
when i draw the spline I don't want to have to manually turn off ortho, osnaps, and change the layer.
i want to make sure ortho is automatically turned off, well that's self-explanatory - it's supposed to be a spline. I want osnaps turned off because I'm working around alot of details and can't stand to snap to things i don't want to snap to. I like for what I do to be fully automated.
Like when I right click, on pick 'Linear Dimension' (custom menu) it automatically puts it on Dimensions layer... get it? same thing when I click 'Dynamic Text' - automatically goes to Text layer, and so on...
And after the lisp routine has finished, and has made the spline into a revcloud, I want to be sure all my snap settings revert back to where they where before I invoked the command. Because acad's stupid .revcloud lisp resets all osnap settings!
« Last Edit: October 24, 2008, 10:41:11 AM by Robert Holland »
« Reply #54 on: October 24, 2008, 10:42:03 AM »
Do a search for CAB's PL2CLOUD.
Notsober
« Reply #55 on: October 24, 2008, 11:18:53 AM »
that doesn't help me.
I already have a lisp that does *mostly* what I need it to do... I just wanted to make it better with an error function.
besides, you can already make a revcloud out of an already existing polyline, by simply clicking REVCLOUD, right click - or from cmd line, choose Object, then pick the pline.
But I liked better the idea of freehanding a spline into a shape around all my revisions without the "boxy" look. Plus, if I need to make rev's to the rev... I can simply right click on the cloud, turn it back into a spline, edit it however I want, then turn it back into a cloud.
« Reply #56 on: October 24, 2008, 11:23:49 AM »
Simple example
(defun c:Test (/ oOs)
Man work gets in the way again.... see Alan posted something before I could get back and finish this..... :cry:
« Last Edit: October 24, 2008, 12:31:14 PM by T.Willey »
« Reply #57 on: October 24, 2008, 11:30:10 AM »
Or what. 8-)
(defun C:RS (/ *error* user_layer user_os user_ortho)
  ;;  always localize this routine!!!!!
    (if (not
          (member msg  '("console break" "Function cancelled" "quit / exit abort" "" nil)))
    (setvar "osmode" 0)
    (command pause)
  (*error* "")
Notsober
« Reply #58 on: October 24, 2008, 11:40:29 AM »
AWESOME!!
 :love:
« Reply #59 on: October 24, 2008, 03:57:27 PM »
Glad I could be of service.  :-)
