Author Topic: How do I get the extension of a selected dimension  (Read 3117 times)
Humbertogo
« on: August 10, 2006, 04:05:57 AM »
How can i get the extension  defining point X and Y from a select Dimension?
for example
1st extension  defining point: X=   0.0000  Y=   0.0000  Z=   0.0000
2nd extension  defining point: X=   2.0000  Y=   0.0000  Z=   0.0000
dimension line defining point: X=   2.0000  Y=   0.6359  Z=   0.0000
« Last Edit: August 14, 2006, 07:09:23 AM by nivuahc »
Re: Dimension
« Reply #1 on: August 10, 2006, 04:15:30 AM »
You could try the DXF values as indicated by this ..
(defun c:dxflist (/ eko)
  (setq eko (getvar "cmdecho"))
  (setvar "cmdecho" 0)
  (setq *lent*
         (entget
           (car (entsel "\nSelect entity to display its DXF value data: ")
  (textscr)
  (list *lent*)
  (foreach n *lent* (print n))
  (setvar "cmdecho" eko)
Command: LIST
Select objects: 1 found
Select objects:
                  DIMENSION  Layer: "ST-DIM"
                            Space: Model space
                   Handle = 1d56
associative: no
type: horizontal
1st extension  defining point: X=  3970.67  Y=  1540.87  Z=     0.00
2nd extension  defining point: X=  5294.07  Y=  1949.35  Z=     0.00
dimension line defining point: X=  5294.07  Y=  2486.82  Z=     0.00
default text position: X=  4632.37  Y=  2521.83  Z=     0.00
default text
dimension style: "STD35$0"
dimension style overrides:
 DIMADEC     1
 DIMSCALE    10.00
Command: dxflist
(-1 . <Entity name: 7ef6e7b0>)
(0 . "DIMENSION")
(330 . <Entity name: 7ef68cf8>)
(5 . "1D56")
(100 . "AcDbEntity")
(67 . 0)
(410 . "Model")
(8 . "ST-DIM")
(100 . "AcDbDimension")
(2 . "*D108")
(10 5294.07 2486.82 0.0)
(11 4632.37 2521.83 0.0)
(12 0.0 0.0 0.0)
(70 . 32)
(1 . "")
(71 . 5)
(72 . 1)
(41 . 1.0)
(42 . 1323.4)
(52 . 0.0)
(53 . 0.0)
(54 . 0.0)
(51 . 0.0)
(210 0.0 0.0 1.0)
(3 . "STD35$0")
(100 . "AcDbAlignedDimension")
(13 3970.67 1540.87 0.0)
(14 5294.07 1949.35 0.0)
(15 0.0 0.0 0.0)
(16 0.0 0.0 0.0)
(40 . 0.0)
(50 . 0.0)
(100 . "AcDbRotatedDimension")
(-3 ("ACAD" (1000 . "DSTYLE") (1002 . "{") (1070 . 40) (1040 . 10.0) (1070 .
179) (1070 . 1) (1002 . "}")))
Humbertogo
Re: Dimension
« Reply #2 on: August 10, 2006, 04:32:11 AM »
But how to do it from vba?
i know that you can get the  extension  defining point from a AlignedDimension
ExtLine1Point
ExtLine2Point
but not from RotatedDimension
Re: Dimension
« Reply #3 on: August 10, 2006, 04:38:57 AM »
Sorry, I didn't notice this was in a VBA forum ..
Re: Dimension
« Reply #4 on: August 10, 2006, 04:50:49 AM »
I believe the points are not exposed to ActiveX for Rotated Dimensions.
edit :
I believe the points for Rotated Dimensions are not exposed in ActiveX .
« Last Edit: August 10, 2006, 05:14:49 AM by Kerry Brown »
Humbertogo
Re: Dimension
« Reply #5 on: August 10, 2006, 05:00:32 AM »
that is  true
you are right
Bryco
Re: Dimension
« Reply #6 on: August 10, 2006, 10:17:47 AM »
Lisp is the way
'SomeCallMeDave
'http://www.vbdesign.net/expresso/showthread.php?postid=83887#post83887
'Changed pAcadObj As AcadObject to pAcadObj As Object to access imagedef as well
'Modified by Jeff Mishler, March 2006, to get the Block table object, not Block_Record table object
Public Function vbAssoc(pAcadObj, pDXFCode As Integer) As Variant
Dim VLisp As Object
Dim VLispFunc As Object
Dim varRetVal As Variant
Dim obj1 As Object
Dim obj2 As Object
Dim strHnd As String
Dim strVer As String
Dim lngCount As Long
Dim i As Long
Dim j As Long
On Error GoTo vbAssocError
If Left(ThisDrawing.Application.Version, 2) = "16" Then
  Set VLisp = ThisDrawing.Application.GetInterfaceObject("VL.Application.16")
Else
  Set VLisp = ThisDrawing.Application.GetInterfaceObject("VL.Application.1")
End If
Set VLispFunc = VLisp.ActiveDocument.Functions
If Not TypeOf pAcadObj Is AcadBlock Then
    strHnd = pAcadObj.Handle
Else
    Dim lispStr As String
    lispStr = "(cdr (assoc 5 (entget (tblobjname " & Chr(34) & "Block" & Chr(34) & Chr(34) & pAcadObj.Name & Chr(34) & "))))"
    Set obj1 = VLispFunc.Item("read").Funcall(lispStr)
    strHnd = VLispFunc.Item("eval").Funcall(obj1)
End If
Set obj1 = VLispFunc.Item("read").Funcall("pDXF")
  varRetVal = VLispFunc.Item("set").Funcall(obj1, pDXFCode)
Set obj1 = VLispFunc.Item("read").Funcall("pHandle")
  varRetVal = VLispFunc.Item("set").Funcall(obj1, strHnd)
Set obj1 = VLispFunc.Item("read").Funcall("(vl-princ-to-string (cdr (assoc pDXF (entget (handent pHandle)))))")
  varRetVal = VLispFunc.Item("eval").Funcall(obj1)
vbAssoc = varRetVal
'clean up the newly created LISP symbols
Set obj1 = VLispFunc.Item("read").Funcall("(setq pDXF nil)")
Set obj1 = VLispFunc.Item("read").Funcall("(setq pHandle nil)")
'release the objects or Autocad gets squirrely (no offense RR)
Set obj2 = Nothing
Set obj1 = Nothing
Set VLispFunc = Nothing
Set VLisp = Nothing
Exit Function
vbAssocError:
  Set obj2 = Nothing
  Set obj1 = Nothing
  Set VLisp = Nothing
  MsgBox "Error occurred " & Err.Description
End Function
And an example
Public Function DimRotation(objDim As AcadDimension, varPick As Variant)
'code(10)=cross point rhs of text,arrow2
'code(11)= text insertpt
'code(13) =Dimstartpt-extendline1
'code(14) =DimEndpt-extendline2
    Dim dblRot As Double
    Dim dblStartToVarPickAng As Double, dblEndAng As Double
    Dim dblEndToVarPickAng As Double
    Dim StartPt, EndPt, arrow2Pt
    Dim varTest As Variant, Ppt, X(1)
    With ThisDrawing.Utility
        'dblRot = vbAssoc(objDim, 50)
        varTest = vbAssoc(objDim, 10)
        arrow2Pt = ParseDxfPoint(varTest)
        varTest = vbAssoc(objDim, 13)
        StartPt = ParseDxfPoint(varTest)
        varTest = vbAssoc(objDim, 14)
        EndPt = ParseDxfPoint(varTest)
        dblEndAng = .AngleFromXAxis(EndPt, arrow2Pt)
        X(1) = dblEndAng - 0.5 * Pi
        Dim dblDist As Double
        dblDist = objDim.ExtensionLineExtend * objDim.ScaleFactor
        Ppt = .PolarPoint(arrow2Pt, dblEndAng, dblDist)
        dblStartToVarPickAng = .AngleFromXAxis(StartPt, varPick)
        If dblStartToVarPickAng > (2 * Pi) - 0.001 Then
            dblStartToVarPickAng = dblStartToVarPickAng - 2 * Pi
        End If
        dblEndToVarPickAng = .AngleFromXAxis(EndPt, varPick)
        If dblEndToVarPickAng > (2 * Pi) - 0.001 Then
              dblEndToVarPickAng = dblEndToVarPickAng - 2 * Pi
        End If
        If Abs(dblStartToVarPickAng - dblEndAng) _
            < Abs(dblEndToVarPickAng - dblEndAng) Then
            dblRot = dblEndAng + 0.5 * Pi * isLeft(EndPt, arrow2Pt, StartPt) 'function
            Ppt = .PolarPoint(Ppt, dblRot, objDim.Measurement)
        End If
        X(0) = Ppt
        DimRotation = X
    End With
End Function
