Author Topic: renumbering block attributes  (Read 8102 times)
ELOQUINTET
« on: August 18, 2005, 02:20:48 PM »
i have been given the task of developing a lisp. let me explain a little deeper before i go any further. we have a symbol which is a circle with an m inside with an attribute which we use to number our motors. we have a couple routines for this task. one will increment the number upon insertion but some users don't use it.  :roll: another one will change the attribute values by a given number. i have been asked to develop a routine that would increment them by one in the order that they are selected. has anyone written anything like this or would anyone be willing to help guide me along?
Biscuits
SEQ.LSP
« Reply #1 on: August 18, 2005, 02:30:22 PM »
Is this close?
;;Automatic Sequential Numbering and Lettering
(defun *ERROR*  (MSG)
  (princ MSG)
  (princ "\nFunction cancelled")
(defun SQN  ()
  (princ "\n")
  (princ SEQ)
  (setq ENT (entget (car (nentsel "\n - Select Text to Number"))))
  (while ENT
    (if (or (= (cdr (assoc 0 ENT)) "TEXT")
            (= (cdr (assoc 0 ENT)) "ATTRIB"))
        (entmod
          (subst (cons 1 SEQ) (assoc 1 ENT) ENT)
        (entupd (cdr (car ENT)))
        (setq SEQ (itoa (1+ (read SEQ))))
      (princ "\nEntity Must be TEXT")
    (princ "\n")
    (princ SEQ)
    (setq ENT (entget (car (nentsel " - Select Text: "))))
    (setq *SEQ (itoa (1+ (read SEQ))))
(defun SQL  ()
  (princ "\n")
  (princ SEQ)
  (setq ENT (entget (car (nentsel "\nSelect Text to Letter"))))
  (while ENT
        (entmod
        (setq SEQ (chr (1+ (ascii SEQ))))
    (princ "\n")
    (princ SEQ)
    (setq *SEQ (chr (1+ (ascii SEQ))))
(defun C:SEQ  (/ SEQ ENT)
  (if (not *SEQ)
    (setq *SEQ "1")
  (princ (strcat "\nStarting Letter or Number <" *SEQ "> :"))
  (setq SEQ (getstring))
  (if (not (read SEQ))
    (setq SEQ *SEQ)
    (setq *SEQ SEQ)
  (setq NUM (numberp (read SEQ)))
  (setvar "cmdecho" 0)
  (graphscr)
  (if (not NUM)
    (SQL)
    (SQN)
  (setvar "cmdecho" 1)
whdjr
« Reply #2 on: August 18, 2005, 02:35:58 PM »
Dan,
This is one I use.  I stripped it out of a bigger routine.  It is written specifically for my block so if you send me your block I can change mine to work for yours.
(defun c:inc (/ ref tobj tstr ttag sel)
  (defun *dxf* (gcode elist)
    (cdr (assoc gcode elist))
  (defun *get_atts* (obj)
    (vlax-safearray->list
      (vlax-variant-value
(vla-getattributes
 (if (eq (type obj) 'ENAME)
   (vlax-ename->vla-object obj)
   obj
  (defun *find* (attlist nlst)
    (vl-remove-if-not
      '(lambda (x)
(vl-remove-if-not
  '(lambda (y)
     (eq (vla-get-tagstring x) y)
  nlst
      attlist
  (defun *put* (obj str lst)
    (mapcar '(lambda (x)
      (vl-catch-all-apply
'vla-put-textstring
(list (rt:remove obj x) str)
   lst
  (defun rt:remove (obj str)
    (car
      (vl-remove-if-not
'(lambda (x)
  (eq (vla-get-tagstring x) str)
(*get_atts* obj)
  (if (and (setq ref (car (entsel "\nSelect reference block:  ")))
  (eq "INSERT" (*dxf* 0 (entget ref)))
      (setq tobj (car (*find* (*get_atts* ref) '("DOOR#" "999" "1")))
   tstr (vla-get-textstring tobj)
   ttag (vla-get-tagstring tobj)
      (while tstr
(setvar "ErrNo" 0)
 (not
   (setq sel (car (entsel "\nSelect attribute to update:  ")))
  (if (/= 52 (getvar "ErrNo"))
    (princ "\nNo object selected, please try again: ")
      (princ "\nRight click detected - Terminate program. ")
      (setq tstr nil)
  (cond ((not (setq tstr (itoa (1+ (atoi tstr))))))
((eq ttag "1") (*put* sel tstr '("1")))
((eq ttag "DOOR#")
 (*put* sel tstr '("DOOR#" "240-DOOR#" "96-DOOR#"))
((eq ttag "999") (*put* sel tstr '("999" "101")))
    (*error* (princ "\nNothing selected.  *INVALID*"))
Crank
« Reply #3 on: August 18, 2005, 02:43:51 PM »
This is close to what you're looking for:
(defun AttribNr (/ nwmaat OK ss1 ss2 ss4 g g1 dr type)
(command ".undo" "begin")
(initget "Yes No")
(setq dr (getkword "\nRotate attribute horizontal? <Y> /n "))
(if (= dr "No")(setq dr nil)(setq dr T))
(setq nwmaat (getstring "\nNumber/letter of first block? "))
(if (wcmatch (substr nwmaat 1 1) "[0-9]")(setq type "getal")(setq type "letter"))
(if (= type "getal")(setq nwmaat (atoi nwmaat))(setq nwmaat (ascii nwmaat)))
(princ "\nSelect blocks one by one...\n")
(while (not OK)(progn
(setq vulin (itoa nwmaat))
(setq vulin (chr nwmaat))
(princ (strcat "\n\n" fill in ":"))
(setq ss1 (car (entsel)))
(if ss1
(setq ss2 (entnext ss1))
(setq ss4 (entget ss2))
(setq g (cons '1 vulin))
(setq g1 (subst g (assoc 1 ss4) ss4))
(entmod g1)
(entupd ss1)
(if dr (command ".attedit" "" "" "" "" ss2 "a" "0" ""))
(setq OK T)
(setq nwmaat (1+ nwmaat))
(command ".undo" "end")
Jürg Menzi
  • Oberegg, Switzerland
« Reply #4 on: August 18, 2005, 03:27:16 PM »
Visit my homepage -> Free Stuff -> Free Programs and DL ItemIndex.lsp
A computer's human touch is its unscrupulousness!
MENZI ENGINEERING GmbH
Current A2k16... A2k24 - Start R2.18
ELOQUINTET
« Reply #5 on: August 18, 2005, 04:24:01 PM »
biscuits comes the closest to what i'm looking for but the onlt problem with the routine is what if the attribute is left empty. i can't imagine this situation happening but my boss might be annoyed that she gave me this as a exercise and i found one  :P i will upload the block to the pond so maybe the other routines could be tweaked to work. thanks everybody
ELOQUINTET
« Reply #6 on: August 18, 2005, 04:29:16 PM »
ELOQUINTET
« Reply #7 on: August 18, 2005, 04:39:53 PM »
i noticed another problem biscuit. if the user selects either the m or the text on top the counter gets screwed up. this is a good starting point but has a few bugs that need to be worked out.
Biscuits
« Reply #8 on: August 18, 2005, 04:45:15 PM »
At least it's a starting point. I found this routine a few years back and can take no credit for writing it. Sorry, I'm still at the beginner level and can't be of any further help. Maybe one of the more advanced members can help. Good luck
ImaJayhawk
« Reply #9 on: August 18, 2005, 05:30:49 PM »
Here is one I wrote a little while ago.  Kinda rough...
;; written by me :)  ImaJayhawk (Jonathan)
;; attyinc incrimits attributes of blocks
(defun c:attyinc (/ strg strg2 ss numobj en enlist en2 enlist2 summy changey)
  (initget 1)
  ;;;(setq strg (strcase (getstring "\nATTRIB Tag To Change:   ")))
  (setq strg "NUMB")
  (setq strg2 (getreal "\nStarting Value:   "))
  (and (setq ss
          (ssget (list (cons 0 "INSERT")
                           (cons 66 1)
                           (cons 67 (if (= (getvar "TILEMODE") 1) 0 1)))))
        (setq numobj (sslength ss)
     numobj2 (sslength ss))
        (while (not (minusp (setq numobj(1- numobj))))
               (setq en (ssname ss (- (1- numobj2) numobj))
                     enlist (entnext en))
               (while (= "ATTRIB" (cdr (assoc 0 (entget enlist))))
                      (setq en2 (entget enlist)
                            enlist2 (strcase (cdr (assoc 2 en2))))
                      (if (= enlist2 strg)
 (setq changey (subst (cons 1 (rtos strg2 2 0)) (assoc 1 en2) en2)
strg2 (1+ strg2))
 (entmod changey)
 (entupd enlist)))
                      (setq enlist (entnext enlist)))))
Jürg Menzi
« Reply #10 on: August 19, 2005, 03:43:25 AM »
Hi Dan
Seems that ItemIndex does the stuff. The only thing you've to do is to change block name and attribute name in the code:
; ----------------------------- Setting default values:
       BlkNme "M4"     ;Block name
       AttNme "NUMB"   ;Attribute name
       DefMde "Numeric" ;Default mode
whdjr
« Reply #11 on: August 19, 2005, 08:19:15 AM »
Dan,
I modified my code for your block.  It prompts you for a reference block and then will ask for blocks to be updated until you give it a right click.  An example would be if the reference block you select already has a number 10 in it then the next blocks you select would progress by 1 (ie 11, 12, 13, 14, ...).
Hope this helps,
      (vlax-variant-value
(vla-getattributes
   obj
    (vl-remove-if-not
      '(lambda (x)
(vl-remove-if-not
  '(lambda (y)
  nlst
      attlist
      (vl-catch-all-apply
'vla-put-textstring
   lst
    (car
      (vl-remove-if-not
'(lambda (x)
(*get_atts* obj)
  (eq "INSERT" (cdr (assoc 0 (entget ref))))
      (setq tobj (car (*find* (*get_atts* ref) '("NUMB")))
      (while tstr
(setvar "ErrNo" 0)
 (not
      (setq tstr nil)
((eq ttag "NUMB") (*put* sel tstr '("NUMB")))
ELOQUINTET
« Reply #12 on: August 19, 2005, 11:13:50 AM »
whoops missed all the replies. i'll tweak each one and let you guys know what happens. thanks a bunch everyone
whdjr
« Reply #13 on: August 19, 2005, 11:24:27 AM »
OK so you've had 11 minutes to tweak...so whose is the best?
ELOQUINTET
« Reply #14 on: August 19, 2005, 03:12:38 PM »
yours of course will. that does exactly what i want. jurg yours does not do what i want. this is not for doing bubbles. look at my posted drawing. my boss got pissed at me when i told her i got it from somebody because she wanted me to use it as an exercise. i feel kinda bad because she's right but i was sure someone had done and i'm still accustomed to begging.
