Author Topic: Search a text file and return find  (Read 5884 times)
Dommy2Hotty
« on: December 08, 2004, 02:32:49 PM »
Anyone (CAB) have a lisp that would search a text file for a certain word and return any lines that contain that word?  I want to make a text file containing all of our jobs in this format:
2004-160-WD-Newport-Lot115-AR
2004-161-WD-Durbin-Lot64-JW
2004-162-BW-Caroline
2004-163-BW-Caroline-3 Car
Then I was thinking the lisp would call a DCL file that would have a user input field for the search item (e.g. Caroline).  The results would be displayed in a box in the dialog box
Results:
This would be used to find job numbers quickly...I'm assuming AutoCAD could search a text file a lot faster than Windows can search a 20 gig backup for filenames...
M-dub
« Reply #1 on: December 08, 2004, 02:36:03 PM »
It's not a lisp routine, but DrawingSearcher will find strings of text within drawings and tell you which ones they are.  You can then bring the results into a spreadsheet if you want a drawing list.  It will also search through many other file formats.
Don't know if that helps at all or not...
Dommy2Hotty
« Reply #2 on: December 08, 2004, 02:46:23 PM »
Not in this particular case...but thank you
I'm going to write this code, but you know how it goes...if someone already made it and you have access to it, why spend the time to code it?  Just fishing in The Swamp...
M-dub
« Reply #3 on: December 08, 2004, 02:50:34 PM »
Can't say that I blame you! ;)
Just wait...when you finish writing the code for it, you'll find out that someone already did it.  That's what Murphy told me, anyway.  :razz:
Dommy2Hotty
« Reply #4 on: December 08, 2004, 03:08:41 PM »
Quote from: M-dub
Ain't that the truth...
David Bethel
« Reply #5 on: December 08, 2004, 03:27:29 PM »
(defun c:stxt (/ output file search nl tc rf tl)
   (setq file (if txt_file
           (getfiled "TXT File to Search" txt_file "txt" 2)
           (getfiled "TXT File to Search" "/acad/" "txt" 2)))
   (setq txt_file file)
   (setq search (getstring t "\nText To Search For:   "))
   (initget 1 "Yes No")
   (setq tc (getkword "\nCase Sensative Search (Y/N):   "))
   (setq rf (open file "r"))
   (while (setq nl (read-line rf))
          (if (= tc "No")
              (setq tl (strcase nl)
                    search (strcase search))
              (setq tl nl))
          (if (wcmatch tl (strcat "*" search "*"))
              (setq output (cons nl output))))
   (close rf)
   (prin1 output))
It would need some tweaking for your exact use, but returns a list of all strings containing the search phrase.  -David
R12 Dos - A2K
Dommy2Hotty
« Reply #6 on: December 08, 2004, 03:30:43 PM »
Murphey strikes again!!!
Thanks David...I'll start with that!
M-dub
« Reply #7 on: December 08, 2004, 03:31:58 PM »
:lol:
Dommy2Hotty
« Reply #8 on: December 08, 2004, 04:35:25 PM »
Thanks again David...here's my modified version...
(defun c:Job (/ output file search nl tc rf tl)
   (setq tc "No")
   (setq rf (open "Z:/JobSupport/Job_List.txt" "r"))
          (if (= tc "No")
              (setq tl nl))
   (close rf)
   (foreach n output (print n))
  (textscr)
David Bethel
« Reply #9 on: December 08, 2004, 06:48:21 PM »
A bit condensed
  1| (
defun c:Job (/ output search nl rf)
  2|
  3|   (
  4|
  5|   (
  6|
  7|   (
  8|          (
if (wcmatch (strcase nl)
  9|                       (
strcat "*" (strcase search) "*"))
 10|              (
 11|   (
close rf)
 12|
 13|   (
textpage)
 14|   (
 15|   (
prin1))
Now to figure out how to have a monspaced font.....
-David
R12 Dos - A2K
Dommy2Hotty
« Reply #10 on: December 08, 2004, 07:22:58 PM »
; error: too many arguments
by the by...colorful...might I inquire as to what you used to color that?
« Reply #11 on: December 08, 2004, 08:03:01 PM »
Never used lisp to do it ... well not exclusively ... I always used "FIND" and specified a redirector to a file ....
find /I "%1" "%2" >> output.txt
Put it in a batch file, supply the search string and path or file to search ...
David Bethel
« Reply #12 on: December 09, 2004, 07:49:41 AM »
It a lsp 2 htm program I wrote a while back.  It is more for true browser use than NG posts.
You would have to get rid of all of the line numbers for the routine to work properly.  Kinda more of an instuctional tool.  I usually provide a link at the end to a working version.
http://www.davidbethel.com/lisp/job.htm
-David
R12 Dos - A2K
Dommy2Hotty
« Reply #13 on: December 26, 2004, 05:27:50 AM »
Got another question concerning this...Is there a way to just return the newest revision of the output?  The revision number in our zip files come after the job number, which comes after the date...you'll be able to tell...
"2003-015-12-WD-Newport.zip"
"2003-015-11-WD-Newport.zip"
"2003-015-10-WD-Newport.zip"
"2003-015-09-WD-Newport.zip"
"2003-015-08-WD-Newport.zip"
"2003-015-07-WD-Newport.zip"
"2003-015-06-WD-Newport.zip"
"2003-015-05-WD-Newport.zip"
"2003-015-04-WD-Newport.zip"
"2003-015-03-WD-Newport.zip"
"2003-015-02-WD-Newport.zip"
"2003-015-01-WD-Newport.zip"
I just want it to return the 2003-015-12-WD-Newport.zip, not all previous revisions.
David Bethel
« Reply #14 on: December 26, 2004, 09:22:12 AM »
In the sample you posted, it looks like (last (acad_strlsort  list)) would work
(last
  (acad_strlsort
    (list
-David
R12 Dos - A2K
